I need to go lower!
AtomicHoe094
Atomichoe094
cleveland, OH
he wants to go lower but run a wide tire is what im reading..
lower-hangers
wide tire-roll the lips or get some different rims with a better offset..
better ride- cnotch the rear for about 4-6 more inches of travel
flip kit would put you too low.
clean454
its gunna take work to go real low (drivable low) and get a really wide tire in the rear.
foreverfalcon40
foreverfalcon40
WOW, not exactly what I want, truck still is my DD so it will see the elements!
My front is fine for now, think its maxed due to crank and tire size. Just want to take the bite out of the rake.
The helper leaf was removed by the preivious owner not by me. Is that the same as the oveload spring?
Shackles...I can just un-bolt stock one's and install "new drop ones"? I know sounds easy...but nothing has been easy on my truck.
---------- Post added at 10:42 PM ---------- Previous post was at 10:39 PM ----------
lower-hangers
Like I said, looking to keep a wide tire for the blower, but not looking for a small tire.
C-notch is fine, to create more space for the rear diff to travel, but then that also means more capability of tires rubbing :(
NO NO NO FIN Way am I ditching my FOOSE's!
clean454
yup im pretty sure we are talking about the same leaf spring
and the shackles are pretty simple
u have to jack the truck up put the frame on jack stands with the axles suspended with the wheels off the ground
then put the jack under the rear diff taking the weight off the springs
unbolt old shackles jack the diff up a few inches line up the new shackle and bolt it up.
bam done u wont see to much drop with the shackles it will help ur rake
but i wasn't satisfied with the drop Personally.
if i were u just get the shackles and crank the keys upfront a little and ur good
then u can run a larger tire and not scrub.
hope that helped
foreverfalcon40
foreverfalcon40
How low of shackle? 2"?
When you say trim? You cut or roll? both?
clean454
ya it gives about 2 1.5/2 inches
and i rolled them and that wasn't enough
then i cut alot
i pretty much cut the fenders just below the top of the flares
thats how much i trimmed but
i dont remember my offset the rims were pretty large and the fenders sat on top of the tire
so i just went to town cutting with out going above the flare and called it a day...
---------- Post added at 07:54 PM ---------- Previous post was at 07:52 PM ----------
heres drop keys-front
rear- shackles and the over load leaf removed
on 6's no scrubing
foreverfalcon40
foreverfalcon40
What size shackles did you go with? Do you still have your fender wells in the rear?
clean454
i went with "2" inch shackles
and yes i still have wheel wells.
foreverfalcon40
foreverfalcon40
What trimming did you do in the rear?
What size tire are you running Width wize?
clean454
then i cut alot
i was on 305 35 22
blanchard7684
