I need to level her out.
Ghostl7
Corinth, MA
I'm currently adapting my Autoride to the lowered stance. 4" coils in the rear and DJM LCA's up front. How much did you cut off the front sensor rods?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Rear rod you chop. Front won't change height
Ghostl7
Corinth, MA
I chopped the rears, maybe 3" overall length but the front made the sensor max out in the up position. This, in my thinking, would confuse the computer and cause the shock to constantly be stiffened. Also, how are people running stock front shocks on a 4" drop. Mine are just way to big.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Get rid of those djm shocks belltechs ride way you better
Ghostl7
Corinth, MA
Or make the stock shocks work haha, I'm tired of short shocks. I'm working on that currently. Ordered dodge 3500 shock brackets that will mount on top of existing shock mount
TheAutumnWind
10x 24 3 inch long machine screw. Cut head off and replace oem rod in rear :)
Huh. I just might try this, and trim the bump stops a bit.
Roughly what kind of ride height does this end up being? Mine is already a little lower then most thanks to the platinum package afaik. Maybe I should measure the links.
