I smell gas
Tiny's Tahoe
West Palm Beach, FL
O.K., every time I fill up I get a strong smell of gas inside the truck. At first I thought maybe the gas cap was bad, "not giving a proper seal". So I upgraded to a locking gas cap with the hopes that it would take care of the problem. No luck. The smell stays for a while maybe 2 or 3 days. I have seen the under body and it looks clean, no rot and very little rust. So i'm shaking my head.
Does anyone have any idea's what could be the issue ?
I have a 99 Tahoe LS 4dr.
I'd appreciate any help I can get, Thanks..
Gzes
the drifting 2dr
Wichita tx
If you smelt it u delt it. Jk try changing rhe fuel filter could be clogged and causing gas to escape from the lines
retorq
Kingman AZ
Check the purge canister and all the hookups ... Also there is a vented and non vented cap, you need to make sure you have the right one for the type of fuel system you have, locking and non locking mean nothing.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
no lines run in the truck obviously but the do run along the left frame rail till the get behind the engine and go up and forward from there. get back down the with good lighting and inspect from the top of tank with mirrors all the way to top of engine. if you smell it you are leaking pretty good and might be leaving some staining behind and i would not drive it till it is fixed.
henchgt
I cant fill my tank fully without smelling gas until I drive around for 70 miles. I found out I have a bad gas tank leak towards the top somewhere. Until I can replace the entire gas tank i just fill her up 3/4 full.
19 tahoe 97
I filled up my truck last night for the first time since I bought it and the same thing happened.
Mitchellbrandon52
