- Joined
- Aug 2, 2018
- Posts
- 7,525
- Reaction score
- 10,287
That's not a bad price, since a new, uncoded BCM costs about $75. So a $50 programming fee is quite reasonable.As a matter of required general maintenance the battery grounds should be replaced. They rot from the inside out effectively acting like a backed up pipe. Essentially it drains slower & slower until it’s time to call a plumber when it doesn’t.
The presumption of the BCM failing goes hand in hand with the grounding issues. The boards get cold joints. The price of replacement is so inexpensive that it doesn’t make sense not to swap out both when the signs are there.
$129 for a coded replacement BCM.
ARES Technologies No1 Reman Pre-Programmed Engine Computer PCM ECM ECU
If you need an engine computer, we are here to help you to identify the right module for your car.arestechnologies.com
