Idle Worse After Plugs and Wires, WWYD?
adriver
If the kid did the entire job, I would be thinking its more likely they screwed up the install. I probably missed it, but lets say you checked all the wires and made sure they were all on tight. My guess would be they didn't seat a plug in correctly, and most likely the #8 plug. That or maybe smashed in the tip on install, and again #8 is the goofy one.
What about pulling spark plug wires one at a time, and seeing if there is a difference. If you find one that doesn't change, then its that one cylinder and not all of them.
CMoore711
My wife’s ‘13 Cadillac ESV is at 110K she babies it, she drives nothing like me. It runs good, but I’ve been collecting belts, filters, new pulleys, and fluids for a good 100K mile maintenance. Cause it’s that time and some of it is preventative while we’re in there.
Part of the list is OEM plug wires which I have and I’ve always ran OEM plug wires; But I haven’t purchased new spark plugs yet. Was going to go OEM 41-162’s, but after reading this leaning towards some NGK’s. I’ve never ran into any issues with NGK’s, but also when OEM is an option that’s typically the route I take.
Whatever you get, get them from a trusted source and ensure they aren't counterfeits. I don't know if your Escalade would take the same plug, but, for my '08 LMG, I went with NGK Iridium IX- part #TR5IX, Stock #7397.
Tyrant
This may come across as heretical, but I run copper plugs in just about everything. Apart from my wife's Jeeps (Pentastar V6 and turbo 4 banger), I've had nothing but trouble with iridium plugs. Swapped to them in my Challenger, idle went to hell and I lost ~2 MPG. Swapped back and the idle was perfect.
I pulled VERY rough Iridiums from my Blown 5.3 (including cylinder 8, which was an OLDER plug and 1/8" longer than 1-7) in favor of copper NGKs and my idle improved there as well.
matty40
