Ignition starter switch
Kimbrow
View media item 28679View media item 286782017 Yukon Denali with push button start.
Anyone know where the ignition starter switch is located? I’ve taken the starter button out and followed the wire back behind the display. Took out the display and it joins another group of wires and goes back into the dash
should be inside the steering column, you have to take the cover off and look inside there, after installing it you might have to have it programmed also not sure.
K
Kimbrow
I’ll check that. I didn’t even think about it running all the way back there.
are you sure that is the right part? just poking around it looks like the push to start button is the ignition switch and the keyed version would use what you pictured but I am just speculating based on photos. if that is the correct part then it should go under (bottom) of the column just under the push button area
K
Kimbrow
They told me I needed both. It’s not under the steering column. Really don’t wanna pull the whole dash but I can’t see it anywhere in there
if it is part number 84126104 it shows it here but could still be different, if you contact your local dealer parts department they can print out the right diagram based on your vin number
K
Kimbrow
US1362 and it looks like it’s a pretty universal part so I’m thinking they gave me the wrong part. I’ll go by the dealership today. Thanks for all your help!
K
Kimbrow
Just talked to the dealership. The switch is the actual button. There’s nothing else to replace. That woulda saved me a lot of time.
dylansmashed
