This is where I have left off until I can get back out there in couple of days.
I still have to figure out something for the gas tank. I had no luck trying to siphon it out. Hoses were not long enough. Is there a hole Ill be able to access from the top of the tank?
I go the U Bolts off, were a little tight.
I did get one shock replaced. Anyone know any torque numbers on the bolts? I have Haynes and Chilton's, one says nothing. The other says finger tight on retainers. Since I ordered Nuts and Bolts for the top of the shock from LMC, I removed retainers. Looks pretty don't she?
I should be able to remove the hose here from the back of the tank to siphon the gas out right? If I have the tank off, should I clean it out? If it needs it I guess.... Probably best to leave it alone so I have less to repair...
There is defiantly not a lot of space to get to some of these bolts.... Whew, I hurt in a couple of places from playing contortionist...
---------- Post added at 10:10 PM ---------- Previous post was at 10:06 PM ----------
The nuts for the shocks are lock nuts. Does that make a difference on putting torque on them?
