Denali4181
- Joined
- Oct 18, 2017
- Posts
- 170
- Reaction score
- 67
I didn’t remove my bumper at all. The large front cover plate once you open the hood is all you have to remove to get access. Just remove the dozen or so push clips and remove the plastic cover. It is a little tight sticking your arm down in between the grill and the hood latch assembly, but it is totally doable. You can reach down and release the stock emblem, then drill out the hole needed for the wire on the illuminated one, then feed the wire through the hole and snap the new bow tie in place. I zip tied the wire every 10” or so and routed the wire over to the drivers side headlight area where it is a plug and play setup online with the drivers headlight assembly.
Good luck!
And you did not remove your grill. The question asked was do you have to remove the bumper cover to remove the grill and the answer is yes.
