I'm at a loss... Can't determine CLUNK sound
GranPrix
17 Tahoe LS with 140k. The suspension has been making a clunking sound front and rear. It was due for a full front and rear end suspension refurb so it has new:
New hardware
New Upper and Lower arms front and rear
Panhard bar
Front and rear factory shocks
New front spring upper seat
New spring insulators
New upper shock mounts
New strut bumpers
New rear upper insulators
Swar bar mounts and links new
Pretty much every component has been replaced new with OEM parts and I'm STILL getting the clunk. Sound only happens on bumps and road imperfections at slow and high speeds. Anyone have any ideas
mrkev
how does your car idle? Could it be motor mounts? Try to isolate the bump by doing things like pressing on the brakes/accelerating/decelerating/coasting/engine-loaded or not
for example, when you are about to hit the bump, drag your brakes a little. This will put tension on the calipers and rotors to rule those out. Could also be Bearings, but that would make a howling sound. and could be something simple like a nut that wasn't tightened. This happened to me before. a bolt on the lower control arm was on, but night tightened.
LegalBrief
Sound travels… where you hear it may not be where it’s coming from.
Sway Bar, Sway Bar Bushings, End Links, Ball zjoints, Tie Rods are all common Kline’s, especially at 140k
GranPrix
GranPrix
After posting last night, I thought about the engine mounts. They’re less than a year old but maybe they weren’t torqued down enough. The hubs are still good and all the bolts were checked.
GranPrix
GranPrix
Like I stated in the original post, all of those items are new
AChevyKing
