In Person Tune
cdhayes2
Goshen, IN
Okay, I'm planning on doing the in person tune in August in Indy, assuming it all comes to fruition.
1. What all happens? Just show up and he flashes it and part ways?
2. I have an ABS speed sensor (along with something else that I'm forgetting) that's bad which causes the ABS light to come on. My local mechanic double checked it for me and said it's nothing critical as long as you keep in mind you dont have ABS. The light is annoying as all get out and fixing the ABS isn't terribly high on my list. Is that something that could be changed to a non-reporting type of deal?
Thanks a ton! :)
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
- you show up at your designated time, and you will drive around with Justin for ~45mins while he tunes. He will ask you questions along the way, and you are able to do the same as well.
-Do you have any reason for your ABS light to be on? Any codes? It is not a problem for tuning, not sure if he could turn it off.
Wannabez71
