Installed an LED Light Bar
YAMBAG
westport MA
Fabbed up a custom setup to mount my 30" Rigid E2 LED light bar. Its secured in place using the bolts that secure the tow hooks to the frame. I will try to get night pics asap.
Donnie Yukonie
Yates Caretaker
Looks great man how much did the bar set you back , I see its a flood/spot combo
xanatost
Lafayette, La.
I like it. Only thing I would be afraid of is it getting smashed on something. Post up some night pics. I been thinking about getting one. How do you have it set up? Did you get there wiring kit with it??
Chevrolado
Redondo Beach, California
Can we get a full shot 3/4 view of the whole vehicle with it?
I'm also very curious on that bar that's holding the LED bar. Thing looks slick. Any info you can give is most appreciated. Did you fab it up yourself or approach a shop or buddy with specific plans or anything?
Nice looking rig and install! Good work.
Y
YAMBAG
westport MA
It's wired up using Rigids wiring harness. Harness runs up the drivers side of the engine compartment and gets power from the AUX fuse block near the firewall. I put the switch in the dash where the push button 4x4 switch would normally go.
Sent from my piece of crap iPhone using Tapatalk
---------- Post added at 07:28 PM ---------- Previous post was at 07:26 PM ----------
I made the mounting bar that the light sits on. The tubing is standard roll cage tubing and the flat stock is 1/8" thick. I am going to make new flat plates for it that are thicker because the bar tends to bounce to much which is annoying as hell at night when the beam of light jumps up and down.
---------- Post added at 07:31 PM ---------- Previous post was at 07:28 PM ----------
Stock low beam lights
Stock light with lows and highs both on
Just the light bar on.
I need to get a pics of it in action on a dark road but I just haven't had a chance yet.
---------- Post added at 07:43 PM ---------- Previous post was at 07:31 PM ----------
Only decent pic I have right now of my Hoe.
BrancoRST
