installed belltech drop
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
prob is at full travel tires might hit so bumpstops prevent this. either way always good do have also helps prevent ds going into trans so far.
that being said links and bumpstops should be there tomm
josueh95
josueh95
i removed my bumstops today and let the truck down and the bumpstop bracket is not hitting with the axle so it only went down 1/8 inch..is there any way to shorten the spacers to like .5"? just curious
Pachanga02
Ny
Makes a big difference with the lower stance. Looking good
josueh95
josueh95
You can cut them down to .5
perfect! Thanks tony..these are rubber right? what would i use to cut these down a bit?
---------- Post added at 11:34 PM ---------- Previous post was at 11:32 PM ----------
thanks :D it just completes the look! ive gotten alot of compliments on the drop and the HD conversion so far..feels good to have a truck you built yourself to your likings
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
4 INCH CUT off wheel they are hallow in center
josueh95
josueh95
thanks! another question when doing the free travel mod cutting the outside of the bracket looks simple but what about the other side? will i have to get under the truck?
WHITEOUT
Dont Hate-Appreciate
Phoenix
Can come at it with a sawzall from the front, and then grind the rest.
josueh95
josueh95
got the spacers and bumpstops today! thanks tony! now i got another question about a body drop..was looking at the truck and i noticed if you do a body drop wont you need to modify the bumpers since they are on the chasis and not the body..like if you drop the rear wont the body hit the rear bumper?
also will shocks up front or shorter end links drop it any more at all? i love having the tahoe at 33" in the rear but the front is at 33.5 because thats as low as my passenger side goes..now i added the spacers and im at 33.75 in the rear but if i could go lower up front someway without adding keys i could lower the back down again
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Will need keys to bring front down more and it might not align so id get a camber bushing kit at same time.
browner010
