installed belltech drop
Bomba02
thanks your denalis looking pretty good aswell..i love your stance what is your rear fender height? and how much travel space do you have in back? my rear is at 33" and the front is at 33.25 hoping to get the rear at .25 or .5" higher. i might look into doing a body drop since it wont change any specs in the front i believe
Thanks man, sorry about the late response im not getting notifyed about updates to New post. At the moment I'm at like 32.5 in the back with 10psi in my bags I have Tony's custom 6 inch springs no spacers. Do you have helper bags, I recommend getting some you can dial in the rear better with some air to little to none and it helps and good for towing if you do any. I have belltech spindles and keys up front I'm at like 32 and I have bell tech camber kit as well. Good stuff. It was lower I recnetly cranked keys up and put air in bags because the roads in mass are getting rough. I have a set of the S-10 body mounts to do the body drop which is on my list to do. Would net around another inch of fender drop. Shouldn't change any specs other then wheel well closer to tire etc.
Billy.
Dflo92
