Installed LED's this morning
bwright81
salt lake city
so my amber 1157 LED's came in this morning from superbrightled.com, those were for the front turn signals and i also did the marker lights and tail lights with LED's from Pep boys, even replaced the signal relay to get rid of the hyperflash issue, problem now is the marker lights up front only light up for the signals but do not come on with park lights? any suggestions:emotions122:
96ProCompTahoe
IN
didn't somehow put them in backwards? (haven't messed with the tahoes lights in a long while, but some bulbs won't work right if you have them spun 180 degrees in the holders.)
setty7
how did the hyperflash flasher work? did it fix that speed?
chauncey0337
MLT, WA
If the parking lights and blinkers are the same bulb you might have the wrong bulb. Make sure your leds are dual circuit leds.
B
bwright81
salt lake city
yeah the new relay was the easiest thing ever and it fixed the hyperflash, ordered it from superbrightled.com as well, part #EP29L, cost $12.99, the marker lights dont exactly match (marker lights are orange, park/signal are more yellow) plus 194 park light bulbs from pep boys only have 1 LED so they are very directional when lit, i have learned the hard way that more LED's pointing in every direction are far superior despite the moderate extra cost!
B
bwright81
salt lake city
ok so i changed out the LED's in the marker lights with some that have 4 LED's instead of 1 and now everything works wonderfully :party33: put the old ones in under my dash for now, here are some better pics than before
setty7
gotcha where does the relay go? also are the leds brighter/go farther than the oem ones?
pickegs
