Installing subwoofer
B
Blakesan
NH
good copy bolo, But I already inspected all those and found this one to be the one I think I want beforehand,
http://a248.e.akamai.net/pix.crutch...er/car/subwoofer_wiring/2DVC_4-ohm_2ch-br.jpg
But since I am semi new to the world of car audio self installation , I want someone that is alot more knowledgeable about this to double check maybe find a better wiring diagram just so I dont blow my new subs and amp. thanks
bolo1g2
The drawing you have is pretty spot on, if you wire it this way, you get a 4 ohm load on your amp and it pushes the rated watts at 4ohm. I have my DVC 1ohm sub wired in series to put a 2ohm load on my amp and it works great.
B
Blakesan
NH
thanks for the help , this is one of my first times doing something with new components so i was just worried.
B
Blakesan
NH
I didn't want to run the wire threw the cab so im going to run it under the body , I got some waterproof kevlar wrap with a hard plastic outside to cover and waterproof/armor the wire so I dont have to worry about it to much , but I was wondering where a good place is to have it 'reenter' the cab? Thanks
ChrisAU
Birmingham, AL
As far as subwoofers in a SUV, rear-firing is the only way to go in a SUV for mid level systems IMO.
B
Blakesan
NH
Anyone have a good place to hook a remote wire in? thanks
bolo1g2
Remote for your amp? Just use the one for the stereo. Tap the same line.
B
Blakesan
NH
So my sub works perfect in the driveway got it all hooked uP , pulled out ,in the 5 feet I drove my subs started pulsing full blast have no idea wats goin on, any help?
