installing subwoofers with stock stereo system
T
theradischad
hello, I wanted to update the status. I hooked it up and everything worked exactly as planned! I found the amp exactly where you said it was (just to the right of the steering column) and wired it to the input converter based on the colors posted. If anyone wants to see pictures just let me know. I appreciate the help tremendously and I could not have done it as cheaply without you guys! :happy160:
lancemanly424
I'm thinking about doing the same myself today. If ya could post some pics that'd be great!
Sent from my Desire HD
lancemanly424
I have a 96 Yukon. From the research I've done I think mine would be the same place. Is that it right there?
lancemanly424
Hmm all I see is this. Don't think it would be the amp though am I correct? I'll feel around and attempt to pull the carpet up to see.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
well the 96 had the abs module to the right of the steering column. Anything safety has yellow wrapping tape or yellow connectors. can you get me the wire colors of the unit under the seat to track it further?
---------- Post added at 02:57 PM ---------- Previous post was at 02:55 PM ----------
Might be a keyless entry module next the the abs as well.
lancemanly424
I feel special. I was looking at the wrong set of wires near there before I just looked. But the colors are Tan. Brown. White. Red. Black. Blue. Dark Blue. So that would mean its the amp right?
SunlitComet
OBS Jedi-Do Good
Well the wires match. Stick a voltmeter on the black and orange wires on the connector. If the volts come up with the ignition on then the stock radio turned on then that is definitely it.
jgrundy13
