Intake Gasket problems...
swamp_fox
My new 03' Tahoe had the rough idle so I replaced the lower intake gaskets with the updated steel core part Fel Pro #MS 98016T. The old gaskets looked like this: http://images1.carpartsdiscount.com/auto/archive/pictures/47727/600/1/P/62F1AFF/chevy_tahoe_2003_intake_manifold_gasket_set.jpg
Except they were green. There was no "clip in style gasket" like I have seen previously. So I took out the 8 individual rubber gaskets and put the new metal ones on the heads. Mounted the intake back up and plugged everything back up. Cleaned the throttle body as well.
I forgot the vacuum line on the evap purge solenoid the first start.
Started it up and it revved to about 3k rpm and starting missing like crazy.
Inspected and plugged up that vacuum line thinking that was the problem.
Now when I start it, it shoots up to 4k rpms and then hangs around 1.5k-2k constantly and is missing.
Its dark out now but I triple checked all of the connections and it is still doing it.
Any ideas?
This is how the bottom of my intake looked, large_2.jpg and I am not confident that the gaskets that I used are the right ones?
---------- Post added at 06:45 PM ---------- Previous post was at 05:57 PM ----------
Did a little more digging and it seems that my intake is an aftermarket piece... Wrong gasket..
Next question is, if I source a new gm intake, can I re-use the lower gaskets or are they just a torque once and throw away?
Or should I just replace the gaskets on this aftermarket manifold?
91RS
GA
Can you post a picture of the aftermarket intake? It may use the same gaskets as a Corvette intake (which are like the ones you pictured).
S
swamp_fox
The picture embedded in the first post is the exact one that is currently on my truck. Each intake runner has its own gasket.
Is there a good set of gaskets to use for this intake?
91RS
GA
Do you have the intake back off the truck yet? I would recommend finding an auto parts store that has C5 Corvette gaskets in stock and take your intake with you and try and see if they fit through the package. I know they use gaskets that look like that, but I wouldn't want you to spend money just based on that. Is there any make or model information on the intake?
Mrsharza
