Intake Gaskets
TogaPC
Austin, TX
Hey guys,
I got a code last week about my knock sensors not working so I undertook the task of replacing them myself. Of course in the process I replaced my intake manifold gaskets. I have to say, it improved my performance noticeably. The gaskets were flattened out quite a bit and there was a lot of buildup on the intake and heads which I scraped off. I used the Fel-Pro Perma-dry Plus gaskets and I must say they are really nice. They have a metal bracket that holds the gaskets in place and it hangs on 2 of the head studs so you can mount the intake easily. Also replace the throttle body gasket and re-wired the knock sensor harness since everyone seems to have problems with it eventually.
Only down side to the whole operation is that I had to buy a torque wrench that does in/lbs. I looked all over town for one I could rent or buy cheap but the only place that had one that would work for the intake bolts was at Sears for $80. So if anyone in the Austin, TX area needs an in/lbs torque wrench let me know...I'll be glad to loan it to you.
Overall, i'd say the difficulty of the job was about a 7 but definitely worth it since a mechanic bills out the labor at $90 an hour and that job is 2.7 hours plus parts.
JKmotorsports
Austin, TX
Cool. Always makes you feel better when you can do the job yourself and everything works out, not to mention the money you save.
Too bad you didn't post about needing a tq wrench; I have both a small in/lb and larger ft/ld wrench you could have borrowed :)
clean454
i helped with knock sensors on a denali not a super hard job but totally worth doing ur self!
Volant1
Volant guy
Upland, CA
I have to do mine as well ive been putting it off for some time, I heard the hole they sit in tends to fill with water, did yours look like they were?
TogaPC
TogaPC
Austin, TX
The back one smelled like a sewer but the front recess seemed fine. I don't offroad but I do like to keep my engine bay clean. Guess that's what I get.
When i checked the wiring harness, I found that the rear sensor wire had a huge amount of resistance so maybe that was the real issue. Either way it's a crappy design on GM's part.
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
Agreed
---------- Post added at 04:45 PM ---------- Previous post was at 04:43 PM ----------
So there are 2 people in ATX with an in/lbs torque wrench...:). Oh well. I guess I'll fine a use for it at some point before I die. Thanks for the offer though.
ford_siesta
