Interior over Haul
deangrell
Why not double up on the struts? Just add add'l struts to the OEM setup. It might look a bit funky...but how often is it open just to show off?
BabyHuey
Bellevue, Nebraska
What is going on with teh back of the driver's seat? Why is it taken apart? Lots of work, cant wait to see it complete.
jcrack_corn
first the bad....i realy dont like the box for the sub....way to square imo....get them to add some big radius edges and wrap in factory match vinyl...just my opionion...i prefer factory blending
now the good...the rest looks great, planning looks great.
regarding the linear actuator it should be no issue at all to program it it to run for a certain time (ie 5 seconds to open , 4 seconds to close) with a few relays and a pic board..your installers should be able to do this. and the factory signal to the current motor would make a fine on/off trigger.
The piece that holds and covers the amps is going to be cut so the amps only show. Once it is cut we are going to rhino line it just like the woofer box.
We have been looking everywhere to find hatch struts that would work and no luck. The OEM's are the strongest that we could find and they are rated at 244 pounds. That rear hatch is heavy as hell without the struts and they have an angle on each tip. I am going to have to do some more research on the hatch shocks before I look into getting an accuator. The only thing that I don't like about the accuator is that you have to hold the button until its completely open.
UofMZ71
i have to agree, i think the rhino lined look is too rugged for the interior of our trucks (would look sweet in a Jeep). Maybe some cup holders and some other factory finished touches to make it blend better
the rest, wow, seems like some work! great planning and 'A' for effort!
timjohnson22
timjohnson22
GEORGIA
The monitors were in before the install but they had to be disconected to run all the wires under the carpet. The amp cover will not be finished until Monday or Tuesday. I will post the final pictures.
taylorsimoneaux
I can't wait to see the battery/electrical system you plan to run all this off of.
Props though, sure as hell not afraid to cut up a new car.
kjetilaf
