Hey George, your video this morning popped up in my youtube feed, I thought you were sliding there for a second!
I am looking at the wiring diagram for the cluster, the gauges to the ECM, there is a Dark Green wire and a Brown and White wire that you might want to check. But that doesn't explain the door locks so I came across the Red and White wire from Fuse 46 (J4 or X4) that goes to your cluster (Pin1). There may be a problem with the pins on the fuse, the circuit board itself or a wiring issue or nothing at all and I'm wrong. Tracing wiring problems is not something I'm good at.
For the Door Locks, they get a signal from that Dark Green wire too, that is the LAN network so maybe there's something wrong with that wire or the connection at either end.
Can y'all see this diagram? I see it during edit but not after saving and posting.
If you can't get it to post see if you can PM it to me as an attachment and I'll see if I can figure out why it doesn't show up.
