Intro-05 Denali Yukon shocks
Zayzay
(Apologies in advance as I’m pretty new to all this) Hi all, I just bought my 2006 Denali Yukon recently and had some questions about the suspension. It does have the RPO code Z55 for the auto ride. However, at some point someone replaced the shocks with KYB gas-a-just shocks and they’re now in need of replacing. Reading through the forum I see that it’s necessary to also replace the springs if you’re going to get rid of the auto ride. My question is, how do I confirm that the previous owner replaced the springs or would one assume they’d have done them both? As well as any recommendations on a new set of shocks? Thank you all in advance for any insight you provide!
I assume you're talking about only the rear shocks. (?)
Don't confuse Z55 with the Premium Smooth Ride suspension (codes ZW7/G65). When those rear G65 self-leveling shocks are changed to conventional shocks, the springs should also be changed to a stiffer spring.
Now, I'm not familiar with the OE Z55 components and what modifications need to be done if the rear shocks are changed, but someone else on here likely will, and will chime in.
Welcome to the Forum from NH.
Pics of the truck, please.
If the truck has the Z55 RPO code, then the rear springs are specific to that active Electronic suspension, and they are softer than an equivalent passive suspension. If you go from an active Z55 suspension to a passive suspension, you need to replace the rear springs with a non-Z55 suspension specification, and those springs will be stronger/stiffer (because that do not have the aid/assist/support of the air bladders built into the Z55 shock).
I have found that the springs have a part number sticker on them, and that sticker remains readable for many years. Check out the existing springs to see if the part number sticker is still readable. If yes, then you will know if the springs are Z55 compatible or not.
Zayzay
Zayzay
Added a few photos, little rusty but have plans to fix that or atleast stop it the best I can! I also included the RPO codes and a picture of the spring, I couldn’t see any part number stickers on it what so ever.
Looking at the springs, I'd say that they are not original springs, and there is no corrosion and/or accumulated road dust on them, and for a GMT800 truck and its age, there should be. As such, I don't know of any way to determine their specs.
mountie
Your RPO shows the "G65" which shows, your original shocks are an adjusting - height, setup.
Your local GM dealer will tell you what is specific for your Denali Z55 suspension, showing your VIN number.
BTW...... Your springs "look" pretty much newer than an original spring would look like by now??
Original factory springs usually have a sticker wrapped on the lower spring, and usually survives the age, to still be readable.
This forum could correct me, but, a Z55, or ( as in my Yukon), has the ZW7 ride..... But there are more than one version of the Z55 ? There are 3 versions of my ZW7 Premium Smooth Ride, depending on the additional, ( no additional ), RPO code, to go with it.
DON'T trust a 'shock absorber' seller...... Their info is NOT reliable !!
Zayzay
Zayzay
I assumed the same considering how good the springs look for a Minnesota truck. I imagine the previous owner did new springs when he did the KYB shocks. I just wanted other input to make sure i wasn't making a mistake by not ordering springs as well. Thank you guys!
I am thinking about ordering the same KYB gas-a-just shocks that are currently in it for all 4. Or do you have any other recommendations? I considered the Bilstein 4600 but they're $150 more for a set of 4
Zayzay
Zayzay
On a different note, I'm also considering doing front and back sway bar end links and front tie rods . However, looking on Rock Auto, the front sway bar links vary in bolt size from 8" to 10" as well as different sleeve sizes. Can you help me understand why that is and what it is that i should order for both links and tie rods?
mountie
To add...... As you describe, " Shocks need replacing".......
I can guess...... Those coil springs are too soft, as if the replaced coil springs may have been ALSO too soft. Your G65 code requires a soft coil spring, because, the original correct factory shock supports a lot of the weight. My guess is, since your concern that you "need new shocks", the springs are still too soft, feeling your worn shocks....
My "non- adjusting" shocks had 175,000 miles on them, but I did not find any issues. And my springs are a tad firmer..... I replaced my shocks due to age, only.
mountie
Hellwig front / rear swaybars. I replace both.... I LOVE them!! Factory swaybars are a hollow pipe...... Hellwigs are a stout solid chrome molly, and all new hardware.
Get a flashlight.... go underneath, look at the ends of your rear swaybar..... Notice the ends are "crimped flat"... Hollow tube..... crap stuff....
bobwass
