Inverter Install 2005 Yukon XL Firewall
dinojr
I am trying to run the cable for a 1000 watt inverter that I am installing under the drivers seat but I dont know where to run the cable through the firewall. Is there an existing hole I can go through. I am using quality cable with excellent shielding on it. If you can include photos I would appreciate it. I am a novice. Thanks in advance. Brian
Brad.r
Hey man I tried to send you a pm but it wont let me?? I did this install, There is a factory hole in the firewall with a rubber boot..
I can send you pics via text if you like, My number is 901-653-8084. If you have an Iphone we can facetime and I will walk you threw it step by step...
Bigsteve04Ho
Under the hood to the right and belowthe steering column is a huge grommet. I used it to run my amp power cable.
