Invision DVD Headrest install HELP
Burbin
Does anybody has access to Invision DVD Headrest install instructions for a 2013 suburban? I have brand new headrest but no instructions. I don't want to screw something up. Drove 9hrs without headrest dvd with 3 kids. Man thank goodness for ipads and ipods
THE YETI
Director of Operations
South FL
It's fairly simple. Hide the brain under the driver seat. Tap into a power source. Ground it. And the rest is plug and play.
Parthery
Atlanta, GA
The most difficult part of the job is removing the plastic covers on the seat backs. Lift up and pop them out. Do not take a screwdriver around the outside or you will break the plastic clips. The panels are over $100 to replace if you break them.
Once the panels are off, it's in easy job. The headrests pop out when you insert an ice pick or paperclip into the release holes. Slide the new ones in...route the wiring down inside the seat frame (be careful the frames have sharp edges). There are holes in the bottom to bring the wire out under the seat. Route all wiring under the seat track and under the sides of the center console. Pop out the center cupholder tray and mount the brain under there and connect the wiring. Power harness runs from there to your fuse block. Negative goes to ground and "+" goes to a switched lead. If you have the GM factory kit there are instructions to top into the junction box located next to the brake pedal.
Total install shouldn't take more than a couple of hours, start to finish.
THE YETI
South FL
I didn't even remove my back panels. Just pulled them enough to get the wires ran down and done.
B
Burbin
Yes I have factory head unit. It has a plug that looks like it plugs into the control box under the dash.
THE YETI
South FL
Those invision monitors have nothing to do with the existing entertainment/radio in the vehicle.
B
Burbin
Why does it have that type of plug that plugs into junction box under dash?
THE YETI
South FL
Just makes it easier to access a power/ground.
I installed these in our suburban. Take the advice for what it's worth.
RepublicanRebel
