iPhone 8 wireless charging
Unit171
NC
Just did it. My 2016 Tahoe LTZ did not work.
Unit171
NC
Only took me about 10 minutes too.... good luck Yukon folks...this Tahoe was no good
dubyagee01
The part he removes looks like a control function. Some sort of induction sensor. I wonder if it will over charge the phones without that part.
Does it charge with the ignition off? I would check for heat from the pad and overcharging.
Sent from my iPad using Tapatalk Pro
Unit171
NC
Just watched again and the magnet wasn’t removed. Only the green “repeater” as he called it. Did I miss something?
Dustin Hartung
In the video the magnet is attached to the green "repeater" My magnet is glued to that thing. Trust me the magnet prevents it from working. I placed that magnet in the center of a different wireless charger i had and it prevents it from initializing a charge. Remove that and i almost guarantee it will work.
Unit171
NC
Okay. Well I’ll go test that theory too. So I’m going to go out this morning and remove the green repeater piece and that magnet. I will only have the copper coil charger I hope.... I’ll take pictures again.
Iopner
Found this last night. Tried it this morning. Worked perfectly, 2016 Escalade. iPhone X
Buzzsaw
