iphone with usb port
LTZ123
Add another one to the list. My brand new 2010 Yukon Denali won't recognize my Ipod Touch. Very frustrated. 1/10 times it will recognize it, but the response is spotty and then it quits.
I will tell you that I had a better luck BEFORE the iPod's moved to the latest iOS version, so tere may be a correlation where the latest iOS is not compatible with the GM Entertainment console.
Does anyone know if GM or Apple is aware of this problem and is offering a fix/firmware update/etc.?
See post #75 and #77.
denali504
NoLa
im having problems with my iphone also with usb port....
sometimes it plays fine and other times it will cut off during a song and i have to unplug and plug back in... its been doing this very often... sometimes everyday
i have not yet found a solution
Don Zone
I can really feel for you. But in my opinion I would suggest that there are two possible issues that can result in USB ports not working error. Firstly, you should check up when you attach a device to your computer, if there is an error message showing up at the right bottom of the desktop which says "USB Device Not Recognized". Then you will need to download a new one from the website of the manufacturer and install it on your PC. Then the hardware will be recognized by Windows system and be able to work. Secondly, if there is no error message "USB Device Not Recognized" showing up, that means your USB driver is damaged or outdated. USB driver is used for detecting USB devices. Without it, Windows system will not be able to detect and recognize any USB hardware. The only way to solve the problem is to install a new USB 2.0 driver for your computer. I suppose the problem always result from outdated or damaged device drivers. Then you will have to solve and avoid hardware not working problems is to update the drivers regularly.
So you just need to download and install new ones for your computer.
I hope you get what you need.
Good Luck..
Regards
nicetruk
Hey all, just caught on to this thread from a google search. Wondering if a new iPod classic will connect to a 2010 Escalade (usb port) with nav and rear seat entertainment (center monitor, not headrests) using the apple supplied 24 pin connector. Any response and/or advice is welcome. Thanks.
LTZ123
Yesterday and today I tried an Ipod Nano 2nd generation (slim blue with a little window) 4GB size - and it worked perfectly. Nav screen was quick and responsive and was able to switch back and forth quickly among playlists etc.
Worked as well as the Iphone4 should - and continued to play (no drop outs).
LTZ123
Well - I can now report some decent success: I reinstalled the 3.1.3 old OS back onto my Iphone 3G and it works perfectly now with my 2011 Tahoe with Nav screen/rear DVD. Ipod comes online automatically when you turn the headunit on or select "Aux", touch response is very responsive, fast and easy to navigate through playlists/menus and scrolling through the lists. I assume that that's all it does - but it's fantastic. I pitched all my CD's from the car - now I have 1,000 songs at my fingertips!
Followed these instructions - pretty simple once you have the 2 downloads:
http://iphonetouch.blorge.com/2010/06/28/how-to-re-install-iphone-os-3-1-3/
Works perfectly now. Fast and responsive - and no cut outs....knock wood.
Would therefore guess that Ipods with version 2.X should work too.
robsieb
Good stuff here LTZ. I was thinking of taking my 3GS back to 4.0.2 and may still look for a way to do just that if the 4.2 updated doesn't fix this problem. Hopefully your contact at Apple will work some magic but I have to say I'll always be a bit scared to update the OS unless they can figure out what really gives.
On another note, has anyone noticed on the iPhone under Settings, General and About, if you are connected to your vehicle via USB it will give you a firmware version under GM. Here are the screenshots showing the firmware 1.0.0 under GM. I did noticed that you have to be connected via USB for GM to show up. As soon as you disconnect it disappears.
attachment.php
LTZ123
Robsieb:
I found that the 3G using 4.0.x worked better than the 4.1.x, however it was still very slow to respond. It was good for having some music, but unable to scroll, and switching playlists and menus was painfully slow.
If you dummy-down, I'd follow the directions I posted - and go all the way to 3.1.3. By the same token you may lose some of the additional features on your 3GS that were improved by 4.1.x OS.
To be clear: I have two Iphone 3G's that are not being used; and dummying-down to 3.1.3 makes them useful....but I don't use them for anything but an Ipod.
LTZ123
attachment.php
4.2 was released to developers today - hopefully on schedule for a "public" release in November?
Seems like it'd NOT be enough time to change for GM - but hope so. :)
robsieb
I'd guess by Apple's track record we'll see the live version of 4.2 in a week to 10 days and I'll do the update (fingers crossed).
Can anyone with a late 2010 or early 2011 model connect via USB and let me know what version of firmware you are showing under GM? Reason I ask is that I was told that the firmware update I received from GM wasn't available to the general public way back when all this first started and I'm curious to see what the newer head units are shipping with now from GM.
MsGofstr
