Irritating -- size of Torx for trans shift bracket?
strad
Las Vegas
99 Tahoe with 4L60E. Of course I'm attempting to change the trans fluid, which is why the bracket needs to come off. I've seen a diy that says the bolt requires a T40. T40 is definitely too big for mine. T30 is too small. Is it possible that it's a T35? Or do I have a stripped bolt lol. It would help if I could see, but I can't.
And if it's a T35, do you know if Harbor Freight might have it? I know Sears has it online, and can get it in the store special order. But I want it now hehe.
S
strad
Las Vegas
No. It's dirty. Not burned, but not nice and pink either. Sorta a tannish pink. 132k miles on trans, did a pan drop and filter change about 12k miles ago, but of course that doesn't get the torque converter or the cooler. I think my 7 quarts of old fluid contaminated the approximately 5 quarts of new fluid I put in.
I might be pulling a 3000-lb trailer 600 miles next weekend, which is why I need to get it done now.
edit: and sunlit, the bracket definitely curves under the pan flange. I don't know how I'd get the pan to clear everything with it in place. There's about an inch between the pan flange and the bracket, and they overlap by about 1/2 to 3/4 inch.
BigBodyBurban
