Is This Tire Wear Normal?
GMT800 SUV/Trucks
What is conversely strange is that, to the opposite, those tiny horizontal nipples/fingers are present on the driver front tire but they are all disappeared on the passenger front tire. It is possible that I routinely make more right turns than left turns.
If you are a UPS driver you will.
B-train
With the driver side being towed in more, its going to pull the passenger side in as the tire tries to straighten out going down the road. Is the steering wheel straight on a flat road with no hands?
I'm no alignment expert by any means, but do understand the basics. It seems as though the camber/caster are in the acceptable area. They definitely just did a set the toe and let it go. A simple bounce of the truck on the rack can give you a slightly different final readout on the camber reading you have
GMT800 SUV/Trucks
I had a shop in KC/MO and my alignment tech was a guy named Jeff Caeser and he was very very good. When he had everything set where he wanted it, he would bounce the front end and recheck and adjust if needed. When the readings stayed the same, after bouncing, he backed the vehicle off the rack and road tested it. He would then double check all areas he had loosened and tightened and then gave it his blessing and parked the vehicle. That guy had no comebacks.
B
BlaineBug
Clown World
Now that's thorough.
B
BlaineBug
Clown World
We took a 2,400 mile road trip shortly after in late January-early February 2023 and I experienced no issues. The previous year in February 2022 we took a 2,600 mile road trip on the old tires and old pre-alignment specs and I also had no driveability concerns to report either during that trip as well.
89Suburban
Bull in the china shop
SE PA
