Just bought 2dr yukon what lift is this? thx
TheAutumnWind
Do u know if it's a 3" or 4"?
---------- Post added at 06:43 PM ---------- Previous post was at 06:42 PM ----------
Do u know if it is 3" or 4"?
Give us a measurement from center of axle to fender.
J
jbloom33
just to the lip of the fender? its 24 3/4" or 24 13/16".. that's from the center of axle to edge of fender
SunlitComet
OBS Jedi-Do Good
unknown at this time.
more complicated then that. the vehicle height was not measured that way it was measured from two points on the suspension parts. but based on the view that has the front diffy dropped it would have to be a 4" at least. a 2" would just normally have some new control arms. any part numbers stamped any where?
TheAutumnWind
Not sure why it's more complicated than that. This is a very simple way to compare ride height without including tire size. Which of course varies.
Sent from my HTCONE using Tapatalk
SunlitComet
OBS Jedi-Do Good
because you need someone here who while components are new measured their fender distance for that particular model setup up. that is near impossible to get here then to top it off expect accurate results from them get a lifted reading with suv in same condition after lift. you could have bent arms, sagging worn t-bars etc in between.
J
jbloom33
Can anyone help please.. I don't see any name or part numbers on it.. no one has seen this type of set up before?
J
jbloom33
OK thanks.. definitely not higher than 4" cuz I've had a 97 4dr with 6" lift and this is not as high.. if it is a 4" and I've check my codes I have 3.73s and posi what's biggest tire I can run.. it's tbi with headers, flow masters, k&n,and throttle body spacer.. don't know if all that really matters cuz I understand gear ratio is what matters but does help the power out some
cannonball155
