Just bought a 2007 Tahoe LTZ, have a few ?'s
a_kraker99
I look forward to contributing to this forum once I get to know the Tahoe a bit better. Feel free to answer any of my questions below. Thanks!
1. Tahoe has 120k on it and never ran E85. I hear you can run a tank through to clean out the fuel system? Is that going to clog stuff up like the fuel injectors since it never ran it before?
2. I have a cylinder 3 random misfire at idle while monitoring with OBD. Changed spark plugs and swapped wires with another plug but still have it on. Possibly the beginning of a bad coil?
3. Tune or programmer recommendation?
4. One of my door handles seems to be broke off a little. Any write ups on how to fix or replace it?
5. I am getting a some knock retard. Up to 4 degrees while accelerating. Is that normal or what might be causing it?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
:welcome:
I moved your thread to the 07+ area instead of the 00-06.
NautiKev
Atlanta
1. I wouldn't waste your money!
2. Switch the coil out with another and see if the skip goes to the other cyl. if it does you got a bad coil. Most likely your problem anyway.
3. BB Tune, everyone here will say the same. don't waste your money on a box tuner. BB is the real deal.
4. Not sure......
5. Probably has to do with bad gas or your cyl misfire.
A
a_kraker99
Thanks, I have heard the Black Bear recommendation before. I will probably go with that.
A
a_kraker99
Another question. Does this engine have a serviceable PCV system? if so where is the valve?
A
a_kraker99
Okay I swapped the coil and wires but I still get a misfire at idle on 3. Clogged injector maybe?
NautiKev
Atlanta
sounds correct unless you have burnt valve, or the valve guides are sticking.
How long has the truck had a misfire problem?
A
a_kraker99
I just got it. I don't think I would call it a problem yet. Just me being picky. It misfires only at idle probably 4 times every 10 seconds.
Jeffro8231
