Just finished my 4-6 drop
Buzzy
Pushes rear end over also I have the adjustable upper and lower arms which push axle back ton recenter it
Does it shift so much that it is necessary? At which drop does it get so far out of place that you need it?
scryfst
Maryland
When I installed my panhard bar after my 2 "- 4" drop the rear was shifted almost 2" towards the right.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
There's a reason I put it as a option on all my kits with 3 or more drop. Deff needed
Buzzy
How is it adjusted? Is the rod threaded with a lock nut or something? Just install it, turn it until rear end is centered and then lock nut in place?
scryfst
Maryland
Sent from my SM-G900P using Tapatalk
Buzzy
What is the ride like with the panhard and sway bar? Firm or like stock but with better handling?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The truck rides sold but nothing like back breaking. I designed my own springs that's why rides well
BLS9
