Keeping coolant and transmission temps under control when towing in the summer heat
alpha_omega
Michigan
Thank you for confirming my illusion confusions. I thought they had both models.
So now there’s a triple threat monkey wrench added to the mix. Which one is better?
I’m also wondering if the engine size plays a role in how well the fan works (i.e. will a 5/5 rimless work better for the 6.2l, whereas the 5/5 rimmed is better for the 5.3l?)
alpha_omega
Michigan
Are there only two bolts holding that fan shroud on? If so I can zip them off real quick and get you guys the numbers and photos from my Denali.
Doing a cfm test will have to wait until I have her back together though. Currently she has no fluids or a front end.
Fless
Super Moderator
Elev 5,280
If you're asking me about the 2005 fans I posted, the answer is yes. The bottom of the shroud has tabs that insert at the bottom, with the two bolts on the top part.
St. Louis
Do you have the K5L rpo?
Larwence
