Keeping coolant and transmission temps under control when towing in the summer heat
Geotrash
Geotrash
Dave
Richmond, VA
a billet torque converter, mine was done with one from a local manufacture from the san jose, ca area, "saxco", there not a "brand name" company but are popular with the locals
Same. Mine was from a national overhauler that my transmission shop works with, called CVC. It's an upgraded OEM unit with a billet cover (stronger, less flex and ballooning), and a stronger lock-up clutch mechanism. The model is BU60FHD.
mikeyss
Longmont, Colorado.
Seriously? I figured at the minimum the plug wires would need to be protected. Usually it’s plug shields and wrapping the headers.
Is yours a 5.3l and is it 2WD/AWD or 4WD? There’s quite a difference in fitment and choice selection between the 5.3l and the 6.2l?
The plug wire and the way the header tubes are positioned, it's like factory. Mine is a 6.2l and 4WD. Once I get it back from getting the exhaust done, I'll snap pics of the plug wires
alpha_omega
Michigan
Good to know. When I was first looking at them Doug Thorley shorties were the only ones that I found that would work with our setup without then being more or less custom built.
Noted…
…billet is the way to go.
alpha_omega
Michigan
Did you guys ever get a chance to check the current draw on the 500w vs 700w fans? I’m still curious if the 700w is going to need the larger amp alternator and if so what size?
wsteele
So I am just guessing here, but I would say the 700W fans draw about 40% more current than the 500W... :gr_grin:
Geotrash
Geotrash
Dave
Richmond, VA
There's always one in every crowd. :) For context, some of us aren't sure if we actually already have the 700W fans as part of the max towing package our rigs came with - even if they don't have the K5L code. And, alpha is looking for info on how much they actually draw in the real world to see if a larger alternator is needed. But your point is valid - it should only be another 16 amps or so.
wsteele
Just foolin’ around.. ;)
alpha_omega
Michigan
No harm no foul Steele…I have had plenty of practice dealing with clowns. Usually around about the end of week one it looks like someone slapped their jester smile sideways when they ask:
“professor will this stuff be on the final exam?”
To which I happily respond: “No, but it will be on the quiz you all are taking in about….seven minutes.”
Jimmy James
