I’ve had to replace a lot of old connectors recently on my 94 k1500, specifically splicing behind the intake which is a PITA laying on top of the motor, these solder seal connectors have been a life saver. Not sure what the consensus is on these but they seem to be a quick way to get the job done. Just cut, expose your wire, slip one of these over, and then hit it with a torch or heat gun and it’s officially spliced soldered and sealed.
140 PCS Solder Seal Wire Connectors - Sopoby Heat Shrink Solder Connectors - Electrical Solder Butt Connectors - Insulated Waterproof Solder Connector Terminal Kit Marine Automotive Home Wiring
https://a.co/d/0CLNpOW
