Knocking sound from the rear
Rockytfox
Still scratching my head.
I kicked the spare tire and heard a noise, so I whipped out the jack tools and I was able to tighten it a bit. Drove around and thought I got it, and then"clack." Only happens when I hit certain bumps. Yesterday I sat in the back and had someone drive. I swore it was the passenger side, then at the end of the ride it sounded like the middle or drivers side. If it's the Arnotts, I'm going to pissed bc I was willing to get OEMs, but thought the Arnotts might provide better handling and a comparable ride for less money.
Sounds like maybe the clanging is coming from the springs. If they are loose or have a spacer, that could be the source.
Yukongk
Yukongk
NY
The saga continues:
Today is warmer and above freezing 36-40* and I only heard the noise twice during my entire commute. Wondering if the freezing temps we were having was causing something in the suspension to make the noise. I'm going to call Arnott and ask them if it could be the shocks performance in cold temps. I'm also still wondering if the spare tire has anything to do with it. I'm going to take it down completely when I have a chance.
Yukongk
Yukongk
NY
......this afternoon was even warmer and guess what? Couldn't reproduce the noise. Seems like its definitely temperature related. Shocks freezing?
Yukongk
Yukongk
NY
UPDATE:
Went for an oil change today. Took a good look underneath while it was on the lift and asked the mechanic to do the same. Everything looks great and nothing is loose in the rear suspension. Mechanic was saying that in freezing temps, the rubber boots stiffen up on the shocks and it's common to have noise. He said some silicon on the boots gets rid of the noise. This makes sense since the noise is now gone and it's finally above freezing.
Wonder if stock shocks do this? This is my first winter with the truck.
Rivieraracing
My air shocks don't make that kind of noise in the super cold but that doesn't mean that yours won't! Cold does some crazy stuff sometimes!
Yukongk
Yukongk
NY
Contacted Arnott. They said if the air bags aren't filling up all the way, this will cause noises to come from the upper mount and bladder housing. When the system is fully inflated the gap between the upper mount and bladder is closed this will not allow noise to come from the shock.
So I guess I need to crawl under there and squeeze the bags after I start it up. This makes sense since the noise is intermittent.
My auto start has been going a bit whacky, and the truck will start, turn off start again, and repeat one more time on occasion. I wonder if this would cause the compressor to not run?
Goldelks
Been hearing a bump all winter when going over big bumps. Ignored it till I went to change the oil. Turns out one of the front link pins is snapped in two. Just another option...
Yukongk
Yukongk
NY
Yea, it actually went away for the most part because its warmer here now (40 degrees and above). Occasionally I hear a noise in the rear that just sounds like I have shocks that are very stiff and not soft. I've also been starting the truck w the key and not using autostart (to test my theory that the autostart malfunctioning was causing the shocks to not fill).
Yukongk
Yukongk
NY
It got cold again and the noise came back. I pulled over and poked the shocks air bags and they weren't filled (soft). I cut the engine off and on and no compressor kicking in. After sitting all day I started her up and still no compressor. Is there a fuse, leveling sensor, etc I need to check?
briwesric
