sensinitas
Purchased mine from V-LED just plug and play.
V-LED
Pic DRL 1LED has OEM bulb on left of pic drivers right. Secon pic DRL 2LED has both LED's installed.
Looks great! Did you use any sort of LED protectors with these?
V-LED
V-LED
I'm pretty sure you need LED protectors for ANY LED's hooked up to the Tahoe's DRL's... I have LED DRL's and have LED protectors on mine...
They ARE "plug and play". It -WILL- work without the protectors. BUT, will they blow? probably. how soon? who knows... didn't want to risk it. Modded said he's been through a few pairs so better safe then sorry!
The LED protectors are needed to protect the LED bulb from power/voltage surges (ex: turning on the ignition/using jumper cables while leds are on/etc) and can be used on any LED's for the DRL/turning signals. Modded showed me these online... I ordered two of these. (Thanks modded!)
http://autolumination.com/equalizers.htm
