Large oil leak driving
RAMurphy
Bob
Military
S. Maryland
@OR VietVet Exactly, They should have focused on all possible avenues of oil leaks based on what they had to clean up. A dented and banged up filter should have been a clue. I also agree with you, oil change and a few other things are the first thing I do when I purchase a used vehicle. I don't care where I purchased the vehicle - brother, friend, dealer or someone I don't know.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Any, new to you, used vehicle should get to a base by changing fluids and of course addressing ANY other concerns found during a thorough inspection. If is brand new, I would still check tension on the oil filter and the oil pan drain plug, based on a couple threads here about new rigs leaking oil asap.
E-Force
sounds like you found the source problem. I've had bad luck with the oil pressure sensor failing and blowing oil all over. this has happened twice! I believe there is a rubber diaphragm built into the sensor that can fail.
06Z71TAHOE
