Leaking roof liner
paulb55
I FEEL FOR YOU! We had this in our Denali. After replacing the XM antenna, and still having 3 more leaks...it was determined it was the sunroof. The had to replace the entire assembly and then there was still problems. I actually went the route of a buy back. I am so sorry you are having to deal with this. Just remember, document, document, document.
Also, they do forget that you can go 3 weeks without an issue because its tied to newsflash...rain.
khiroshima
khiroshima
Thanks for everyone's replies - Just circling back to confirm that GMC replaced my OnStar antenna and sealed it (properly), like 68 describes above, they have seen this issue before. I use ApplePlay for nav, so I didn't even care that nav wasn't working, but they identified that they needed to replace the antenna itself. The job took a day, but they did need to overnight the antenna. I will have to wait for the next rain to see if the problem is indeed fixed (looks like later this week). Thanks again! KH
AngelXL
I'm pretty sure they use a water hose to test...
bobbydon99
