LED Brake Light Repair
I see not many have seen the wonders of a plastic welder, albeit the good one's are a little pricey
trailblazer
I was worried about this failing again that’s why I covered the repair with a small piece of electrical tape and globbed Dynaflex sealant over it. Definitely waterproof and able to handle four seasons. Plus I can scrap it off if I run into issues again (like me repairing this repair). Seems like the best repair would be to either use a humongous glob of solder or preferably a small copper wire so it can handle the flex that is going on in there. What a weird design.
justinb181
Just did this tonight. I pulled the drivers side unit and it appears to have already have had a repair that failed. Seems like you have to either jump it with a wire or use a much more rigid jumper than just soldering the cracks. I suppose globbing the hell out if it with solder would work.
I used a dremel tool with a grinding burr. This was 100x easier than a “hot knife”.
I'll be tackling this soon, what grinding burr did you use? I was thinking about using a cutting wheel but worried it may cut too deep.
trailblazer
I had a carbide one laying in my toolbox and used that one with my Dremel. It is cone shaped. Just take your time and have a firm grip on the tool and light fixture.
BlaineBug
Clown World
If you're in there you may as well do both. Solder to bridge the gap and restore the structural integrity of the metal, but then add a secondary "fail safe" flexible copper wire for good measure too. Fix one cry once?
Mazzmanian
