LED Lighting
NJTaho
NJTaho
Central New Jersey
ROTFLMAO!!!!!!!!!!!!!!!!!!
I can't stop cracking up, that was pretty funny guys.
I ordered LEDs from Super Bright LED's and they came in today. I just installed LED's on the interior and I couldn't be happier. Well I am going to pick up some grease tomorrow. I still have to work in the Mirror/Courtesy lights.
Passenger Side floor with OEM bulb
Drivers side with new LED bulb, what a difference
New LED Map Lights
Middle row LED Dome light
Rear cargo OEM bulb
JochenWoern
Sacramento, CA
New LED Map Lights
Rear cargo OEM bulb
LOOKS GREAT Dan.
Can you provide the exact kit/part numbers and Whom you purchased this from? (Is it indeed "Super Bright" what I need to look for on the internet?)What about cost?
I would like to do this to my Yuk.
Thanks in advance.
chauncey0337
MLT, WA
J Dubya, for smd leds I'd suggest the cheapest ones you can find. Others may disagree but mine are cheap and they all still work after a year. Here's a little list I posted a while ago. Mine's a 2000 but I believe your bulbs are the same. Btw, Dan bought his from superbrightleds.com
Footwell lights(if you have them) are 194's, door panel lights are 194's also, domes are 42 mm festoon, map lights are also 194's, for vanity light's I used 31 mm festoon, window and lock switches will need 5mm leds soldered in, 2000-2002 gauge cluster will need 194's and 2003-2006 gauges will need leds soldered in. I've noticed cheap ebay smd's for domes, doors, footwells, vanity, map lights, and 2000-2002 gauges work well and last. The round 5mm leds are best from vleds or superbrightleds. And use links in previous post for reference.
42mm festoon- http://www.ebay.com/itm/6-SMD-5050-4...item2c5f6e5204
194's- http://www.ebay.com/itm/T10-W5W-194-...item4cfb50edd6
31mm festoon- http://www.ebay.com/itm/31mm-SUPER-B...item336d8b613d
These are just the ones I used and are only suggestions. There are so many other options out there.
JochenWoern
Sacramento, CA
AS ALWAYS, Many Thanks Chauncey!
What does "smd" stand for?
chauncey0337
MLT, WA
SMD- surface-mounted device- resistor, capacitor, led, etc.
NJTaho
NJTaho
Central New Jersey
Chauncey got it, superbrightleds.com
I went with the Cool White with all of my LED's
Map Lights Part #WLED-CWHP15-TAC $6.95
Dome light Part #4410-CW9 $4.74
The Maplights LED is the same one for the floor lights and glove box.
You will need to Order 5 Map lights for the interior, 2 for the floor, 2 map lights, and 1 glove box.
You will need 6 Dome lights, there are 3 in the second row and 3 in the third row/cargo.
MrBalll
West Texas
Good to hear. You will love the new much brighter lights they give you vs the old ones.
NJTaho
NJTaho
Central New Jersey
I already do, I was sitting in the truck yesterday like, wow, this looks nice, and then my girl came out and was like what are you doing? I started explaining and then she was like well, did the lights work before?
LOL
She just doesn't get it, but thats ok. I love her anyways.
kjetilaf
