LED Puddle lamps
Faites777
NOLA, USA
which are the best to use for puddle lights from superbrightleds?
http://www.superbrightleds.com/cat/...olet-tahoe--front+sidemarker/11-1053--437842/
I've tested some of the T10/194/168 bulbs on a Lexus light. The cheap 5050 has 6K-ish white while the new 5630 LED type was brighter but has a purple-ish hue. The single-forward facing bulb has the best correct output for puddle-light usage; those Philips/Oram are expensive because they produce lots of light than any of the 1w-3wattage bulbs.
This was MTec on ebay testing all the differnt bulbs.
http://www.hidplanet.com/forums/sho...son-of-luminous-flux-of-various-T10-LED-bulbs
chadman
I tried prying open the lense cover off at the little indent on the inside end but it wouldn't budge. Are these glued in or something?
I have a 2009.
blkonblk
NYC
No they are not glued they are just a little hard to come off
enypde
New York
Mine came out easy. I used a small flat head screw driver. You gotta put it up a little higher than you think in order to get it out. The clip is a big.
sportyjames
