LED Switchbacks Cut Off In Reverse
MeanGreen03
TX
I just installed some switchbacks and noticed when I shift into reverse the drivers side cuts off for a split second then comes back on. Has anyone else experienced this with LED's? I switched the bulbs from side to side to rule out the bulb itself and it only does it on the drivers side with both bulbs.
Donnie Yukonie
Yates Caretaker
Did you wire in resistors? You know to avoid hyper flash. I know LEDs generally Draw a lower power than regular bulbs. DId you swap in regular bulbs to see if it still does it ? maybe its a coincidence that when you changed to LEDs something happened
schimme
