LED tail light question
95escahoe
I have a 1995 Tahoe and currently have some brand of after market tail lights (came on the truck when I got it think there APC) well they are the pig tail kind push in and twist not the circuit board kind like most Tahoe's have, pretty sure it came factory like that well was gonna pick up some OEM style ones tint them and cut off the pig tails and wire them up to be circuit board cause that's all I can find, well I like the LED tail lights that LMC and others sell, so if I was to pick those up would I have to cut the pigtails off and wire them up that way? or what? thanks for the help in advance
the big blue bus
richmond, va
yes, looking at the picture of the led tails i want they actualy use plugs that plug into where the stock bulbs go and looks like you attach the circuit boar to the back of em
95escahoe
95escahoe
I see, so it would basiclly be the same as wiring up mine to use circuit board ones then
jsmith14
I do prefer the LED aftermarket mate since it’s the new stuff for our trucks but it will be difficult to replace tail light bulb. But I’m quite sure that you’ll be using those taillights for a long time if you’ll take care of them. It’s still your choice mate. Cheers.
95escahoe
95escahoe
thanks for the help/info
RedCrush
saweet, good luck with the tail lights. Most of them are made to plug and play into your existing stock harness. If they are not, i wouldn't even bother going that route.
Snotek27
