LED Tails
rando_smash
Has anyone bought or tried the Depo led tails for 01-06 tahoe? I'm pretty sure they come with built in resistors. I haven't seen alot of ppl with them on here, are they bad or just not up to ppl standards/liking?
BLKTah02
if u install just the rear led taillights do u have install fronts to match?? will u have hyperflash issues??
Tahoewhat
Ballin' on a Budget
TX
I would like some for mine but its a barn door.
They do make them. I had some at work one day and told mike about it, but it couldnt happen.
I bet my 35watt LED reverse lights would be really bright in them!
I have hid's in my reverse lights. Like it was mentioned a couple posts back, w/ leds they tend to be longer than hid bulbs and can possibly hit. My hid bulbs do not hit, nor are they close and much brighter than leds, but take a sec to light up. Going strong on 2 years same bulbs.
-------No hyperflash w/ the correct tail lights---
And for all wondering about the hyperflash. All you need is the tails that have been listed and make sure when looking that it states resistors built in. (it will be a black box on the back side of the tails when you look at the pictures.) For example - Look at the back side picture of this led taillight, right below where the reverse light goes, that little box is the resistor built in.
http://d3d71ba2asa5oz.cloudfront.net/23000025/images/lt-den00rled-tm-a.jpg
I have installed quite a few on my tahoe and never lost normal operation. Just make sure they have resistors and your fine. No need to add one or put in front lights to match.
BLKTah02
wow that's awesome I would think that u would needs fronts too, how about the interior flasher in the dash? do u have to change that?
Tahoewhat
Ballin' on a Budget
TX
Nope no fronts needed. if you click my sig, that says "My Tahoe" I have led turn signals not the bulb, the full led turns, and led tails. No problems with flashing at all. Just resistor built in is the key word when purchasing them.
The interior flasher Nope. Nothing, just again, purchase w/ resistor built in the lights and you are fine. (should be) there is always that one. Just dont go w/ a really cheap set, b/c then as the saying goes, you get what you pay for.
Feel free to pm me w/ any questions.
CM Burns
Alabama
Are the LED tails one piece until they burn out? or can you actually replace an LED 3057 bulb when maybe a tail light goes out like the factory setup?
THX
Vette66
Fresno, Ca
You guys should really check out the Tech section on people that have already installed tails. No you don't need to match front LEDs if you put LED's in the rear. The 3057 bulb will cause hyperflashing, cruse control issues, and on 03-up will cause bulb out on dash if that's what you are asking.
LED's are not replaceable unless you open it up and replace them directly from the pcb. So not a plug in play kind of deal but I guess with hours of time it could be done. LED's have 30x the life of a filament bulb so you should never have to change one out.
Grimes
If its still worth anything to OP, here are the pics I was talking about, Top set of LEDs is brake, which has 2 stage for tail light and brake light. Second set is the blinker (hazards in pic). Didn't get one of reverse, but that is up to you as the bulb is not included. However, I suggest a BRIGHT LED. As in, on superbrightleds.com get the ones with 4 or 5 bulbs in relative brightness (believe over 140 lumens).
S
Stein2088
Butler, PA
I have Spyder LED tails listed in the classified section
I've never heard of resistors being "in" the tails, as I've been told you have to wire them up front. However, I say screw resistors and their heat, and check this.
Here is a link to smoked tails I purchased some 2 weeks ago. They around maybe 2mm shorter than stock, but still fit perfectly. Note: You WILL have to take the bevel clasps off of the stock housings where they screw in, but you'll see what I mean. They look amazing, truly amazing. I am doing my camera work this next week after some plastidipping, so will be sure to link it in this thread if you haven't decided yet. Also note that a bulb for the reverse is not included, so get you an LED while you're at it!
Now, for your hyper flash. I have heard that not everyone experiences it for some reason. For the sake of time, I didn't care to test it, and I ordered this nifty product off of Amazon.com at the same time as the lights. It will replace the flasher module under your dash, allowing for the negligible power draw from the LEDs. It is plug n' play, and gives a nice new blinker sound (not tick tock, more like thump thomp) that is lower in frequency and simply less loud. Works as it should.
You mentioned you wanted factory, and I insist that those LEDs look aweesome, awesome, awesome. They are lightly smoked, much more gray than black. However, if you are looking for no tint at all, still look for housings from that seller.
Grimes, those look like the Sonar lights with resistors built in already. They are an exact match to mine. You went the way I did and bought an led flasher. In my opinion it is the only way to go. I don't see why people would hack up their wiring harness to install resistors.
---------- Post added at 08:38 AM ---------- Previous post was at 08:07 AM ----------
If they are not too long. I tried DDM's cree lights in the first set, the sonars, and the bulb hit the lense knocking them out.
Hey everyone thanks for all of your help I appreciate it. I'm glad to see there is a plug and play fix that doesn't require cutting up the pig tails. Thanks Grimes. Tojo I saw your lights a few weeks ago but I'm wanting something that looks like it came from the factory. Here are the two I'm considering.
Option 1
http://www.autoanything.com/lights/73A5222A0A0A3279168.aspx
In my opinion these look more for a GMC with the reverse light down low. (yes I know they will fit mine)
Option 2
http://www.xtralights.com/00-06chevytahoesuburbangmcdenaliledtaillightsg2-redclearpair.aspx
This is my personal first choice. With the reverse light in the middle similar to my factory lights and new Chevy's. I believe they are "G2" Has anyone heard of complaints???
Vette66
Fresno, Ca
Both look totally not factory. People have had #2 option and complained about the split. Upper is turn and lower is brake. Or something like that. TBH IMO the bigger and brighter a brake light can be the better. I obviously like the combo turn/brake. And they are freaking bright. To each their own.
Btw I pretty sure GMC and Chevy tails are the same. or my GMC had the higher or middle reverse light. quga2eme.jpg
gknowels
