Leds for Taillight
PauliePucks
NJ
Tail light and indicators I am 100% sure. Have not seen the reverse lights in person yet, but assuming LED there also. Pretty sure your previous generation Yukon had LED reverse too?
I can confirm LED reverse lights on Yukon XL SLT
Blueinterceptor
Regarding the led bulbs. Did you try reversing the bulb install to avoid the error code?
Aaron 21 Tahoe
Hello! First post here. I too tried LED bulbs in our Tahoe and instantly had the warnings on.
I am hoping that there will be a good set of aftermarket lights that will not cause faults. I also hope they will look close to the OEM design.
79jasper
I tried a different set of CANBUS leds from Amazon for the reverse light. They look awesome but I can’t deal with the “check reverse light error”. Especially bothersome as I was the first poster for the service safety restraint error.
Not all bulbs are created equal.
Sent from my SM-N960U using Tapatalk
StevenLynaugh
Has anyone had any luck with a Bulb brand that works?
I’ve tried LASFIT’s CANBUS free bulbs..Check Lamp popped up. So tonight I spliced in Resistors and the warning popped up again..
StevenLynaugh
Anybody look into replacing the following bulbs in their tailights? I could not find sizes in the owners manual.
1. Stop Lamp
2. Turn Signal Lamp
3. Back-Up Lamp
I used these Turn Signal Bulbs. No error and they’re bright. Still no luck with Brake light and reverse bulbs..
Bigmanny
Bigmanny
I may try those turn signal bulbs, those and the brake don’t look terrible. The old halogen reverse light is so ugly and dull. Somebody has to make a canbus that works with GM. I would think that the 19-21 Silverado would be similar?
AceDawg
