Left turn noise
David Paul
Central NJ
When I turn left, it sounds as if the abs is kicking in. It happens mostly when the truck is cold and only on the first couple of left turns. Sound coming from left front. Power is decreased, but no abs active light comes on.if I lift off the gas, noise stops and everything seems fine until the next cold left turn. Any ideas?
Thanks
David Paul
David Paul
Central NJ
Travis,
Check the ABS & Traction control activates for no reason thread in the General Discusion section. I believe that is my issue. Hope this helps. Since I have 150,000 miles on mine, I'm going to replace both front hubs to see if that fixes the issue. If not, at least I won't have to worry about them in the future....
Yukie2010
