mountie
- Joined
- May 9, 2018
- Posts
- 5,350
- Reaction score
- 10,119
If your dealer accepts ANY attempt to repair "as per your complaint", MAKE SURE THEY HAVE IT IN WRITING PER DEALER...... They will only attempt a factory warranty item. If they do make an attempt, and fail...... many times the 'failed repair' becomes an ongoing complaint WITHOUT A YEAR/ MILEAGE LIMITATION. ( I lived in California)....... But dealers may blow you off due to this fine print. (( read your warranty..... This may be written in there somewhere. ( It was in my warranty book) But that was a while ago...... It may have changed since then?
Oh, yea..... CHECK FOR A "TSB" ( Technical Service Bulletin ) on your exact concern. Others may have a same issue...... GM won't volunteer this report of a defect...... But the TSB must be described same as your complaint. Make your complaint same as the TSB description. ( If there is one)
