Let's see some pics of some lifted and leveled
Sarge
South Alabama
Where you get those mounting brackets? About 1" in between the holes? Thinking that looks easier than extending the rods. Thanks.
About 1/2'' between the holes and raised the rear a good 1''. Guy i know in service got them for me. Ordered them through General Motors.. it is what they use on the new yukons and trucks when they do leveling kits etc that have air. Ill try and get a part #. Easier yes, but not adjustable. They are made for a 2'' lift but you can drill a hole down some and make it longer or just get a piece of metal and make your own
09TahoeLT
4 inches up front, 3 in the back. 33s and a 20x12 with 2 inch spacers all around.
Beautiful Tahoe! What lift kit are you running if you mind me asking and do you rub a lot in the front?
Burb!!
Biloxi, MS
My rims are 20x12 with -44 offset, so i hade to trim alot more than what procomp said. I cant add the trim brackets yet until i fab something up that fits a little better. Surprisingly enough, i didnt have to do the norcal mod yet. But il find that out once i take it through a field.
Looks amazing!! I'm thinking about the same specs for wheels. Are your tires 35s and what are your ground to fender heights right now?
Sent from my LG-H900 using Tapatalk
Lifted07
42 in the rear and i think 43-44 in the front. I did end up doing a small norcal mod just because i had everything to do it already. Front bumper trimmed x1.5 as much still rubs in reverse at full lock.
Burb!!
Biloxi, MS
I knew it!! Thanks for confirming it. Doesn't look like I'll need the "norcal mod" like I was previously told. I'm at 46.5"front and 45"rear on my ground to fender heights...I just had to ask somebody with the exact wheels I'm trying to get.
09TahoeLT
Deets in sig.
Beautiful Yukon
What kit are you running
techrider
