Let's see some pics of some lifted and leveled
ta07hoe
Rough Country 3.5" lift on 33x12.50r20 Falken Wildpeak MT tires. It is an LTZ so had to account for autoride, but got it to work with brackets. Can include pictures of how that was achieved if anyone wants them.
That looks perfect. I want to do the same to mine. Any trimming required or rubbing? How are those tires
Lil_Stump
Brunswick, GA
There is minor rubbing on the plastic, bu it's at full lock, so not enough for me to bother trimming. I opted to not put spacers on my stock wheels like recommended, so you may have different and better results with some quarter inch spacers. Loving the tires, they're very quiet for a mud tire, and I got them at a great price. Would highly recommend them as of right now.
ta07hoe
What size wheels are those and offset and back space? I'm looking to do 20x10 with a -19 ish offset
Lil_Stump
Brunswick, GA
Honestly not 100% sure, I've looked for exact numbers before, and never found any for these wheels. They were apparently a factory upgrade. I believe that they are basically the same as the other stock Tahoe wheels, so 20x8.5 and +31 offset.
Bigmac18
I was able to fit a set of 305/55r20 on factory wheels with 2" spacers on mine, If my math was correct, it would be about the same as a 20x10 -19mm offset wheel. I had to do a TON of trimming though on top of the 3" front and 2" lift rear.
ta07hoe
Those tires are the same height as mine but just 1 inch wider. Mine clear no issue with a 2" level. i think since you had em on a stock wheel they probably were an inch or so taller than if they were on a 10" wide.
bleedingknuckles
