Leveling kit & body roll/sway
amighjm6
martinsburg, wv
Installed 2.5" front spacers last week, and things were fine. installed the rear 2" spacers over the weekend, along with some 275/70/18 BFG A/T's, and now i have some pretty bad body roll/sway. i'm assuming it must be from the rear spacers...the tires are E rated 10 ply and i'm running 60psi, so if anything, that should help with any roll/sway i would think. the sway bar endlinks are tight, the alignment is good...anyone else have this problem? any ideas?
thanks
josh
UofMZ71
try letting some air out of the tires. I have nearly the same size and am running 40-45 psi
MOBmentality
Has a $25,000 Punch
+1 the tire acts ass a buffer before the suspension sees the road... and a softer tire will provide more of a shock like quality , where as a stiff tire forces the vehicle to rely entirely on the suspension..
Erlin
