leveling kit steering issue
whitey hoe
Please comment is you have a leveling kit and have not had this issue.
I've searched and found nothing about this issue.I'm wondering if something is wrong with my Tahoe.
I've done a 2 1/2 spacer lift w 1 1/2 spacer in rear w moog springs,extended bils all around.I did notice some problems until I installed extended sway links,bump stops ,extended cognito and jounce stops up front,then idler and pitman new.I'm sitting at 39 1/2 front,40 1/2 back,rides better than a Cadillac but only after all proper length pieces installed.A key lift really does need all the pieces to make it work.160,000 miles on odometer so I suppose I needed all anyhow.
Mrobinson
Mine seems to jerk alot upon excellaration off power drives like a Cady keys with z71 springs I'm at 23.5 from center of hub to fender well.any help will be appreciated
Mrobinson
I made this to correct my issue,it worked great ,I also installed cognito pitman arm brace
SRADKINSON
